When I put an object in Maintenance Mode through SquaredUp and fill in the additional comments, how do I go back and see that information? Is there a way to dashboard who did it, reason and additional comments?
Currently, there’s no way of viewing this info in Squared Up v3, though this was possible in v2. Probably best to send a request to support.
You could write a SQL query to pull MM info, though I wouldn’t know where to begin with this, as I’m not even sure which DB it’s stored in
Give this a try…
- Add a new SQL tile to a dashboard
- Choose SQL (Table)
- Use your OperationsManager database. For example:
- Data Source=FQDN.Of.Your.OpsMgr.DB;Initial Catalog=OperationsManager;Integrated Security=True;
- For your query string, use the following SQL:
I found the above SQL code at this web site: http://www.culham.net/sql/what-scom-objects-are-in-maintenance-mode-sql-query/
Brilliant, thanks, looks like that will do the trick.
Had to replace ‘’ with ‘’ to get it working.
