It has been observed that we are not able to see its performance data except Processor Information for one of our Management servers, would like to check if anything is stopping at SquaredUp side or any issue at that server, SquaredUp screenshot.
Any pointers to troubleshoot this, as this is priority since we have to fetch those performance counters…
From the screenshot, it looks like you might just be showing ‘favourite metrics’; have you tried the ‘show all’ button and, if so, does this make a difference?
If you bring up the same server in scom. Do you see more performance graphs there?
I´m not running v. 2 anymore so I cannot check how it worked on that version. But could the missing counters be connected to timeframe? If you select 24 hours?
