Vmware vcenter integration - CPU & Memory sizes in grid tile
Running SQU DS v7 - Just configuring new dashboards for our VM Admin and I have a query re the Grid tile, how do I convert the presented numbers for various data sources like totalCpu, totalMemory etc. into GB? I’m assuming I can create custom columns but some guidance on the syntax to convert would be great.
Also are there a % free metrics hiding away somewhere?
The new integration is awesome but at this stage we are losing some of the detailed nuance we get out of the old script based dashboards.
For converting numbers, the usual moustache options should work.
There are some further examples here - VMware tile | SquaredUp SCOM Support and samples/mustache-and-custom-labels/convert-and-round-values.md at master · squaredup/samples and here Mustache pickers - SquaredUp DS
This suggests we should put them together more logically which I’ll look into.
Let me know if you get this working and we can then look at the other questions. And please don’t hesitate to use support for these questions.
