Why has a previously working Heat Map stopped showing heat?
Hey everyone,
Anyone have any idea why a previously working heat map would suddenly stop showing heat?
There are a few messages, but no errors or warnings. Messages are:
  1. [Violation] 'DOMContentLoaded' handler took 1457ms
  2. [Violation] 'requestAnimationFrame' handler took 1225ms
  3. [Violation] Forced reflow while executing JavaScript took 67ms
None of these indicate a failure to load, just the time it took to do so.
Kr,
If you press F12 and select the Console tab, and then refresh the page do you see any error messages?
I made the mistake of answering this post instead of updating (my first post) . Any idea how to undo it? Or do I need to create a new one?
