As I begin to create a dashboard (using Powershell mainly) I have started with pulling in data from several CSVs and creating a line graph. As far as I can tell, this data has a valid timestamp column ( in the format MM-dd-yyyy HH:mm:ss) and valid value and label columns.
The data starts plotting from left to right on the line graph. And it is updating. However, the X axis times are entirely wrong. For instance, I am collecting this data every 5 minutes. It is currently 7:30 PM here, but the line graph is showing 3 PM for the data points. Is this due to UTC vs my current time zone? If so, what do I do to fix this?
Some example response data:
timestamp value label
8/12/2022 7:03:37 PM 1.898734 CPU Core #01
8/12/2022 7:07:33 PM 1.931613 CPU Core #01
8/12/2022 7:08:37 PM 0 CPU Core #01
8/12/2022 7:13:37 PM 0.625 CPU Core #01
8/12/2022 7:18:37 PM 0 CPU Core #01
8/12/2022 7:23:37 PM 0 CPU Core #01
8/12/2022 7:28:37 PM 3.797468 CPU Core #01
8/12/2022 7:03:37 PM 1.265823 CPU Core #02
8/12/2022 7:07:33 PM 1.923077 CPU Core #02
8/12/2022 7:08:37 PM 0 CPU Core #02
8/12/2022 7:13:37 PM 0 CPU Core #02
8/12/2022 7:18:37 PM 0 CPU Core #02
8/12/2022 7:23:37 PM 3.125 CPU Core #02
8/12/2022 7:28:37 PM 3.797468 CPU Core #02
8/12/2022 7:03:37 PM 0.6329114 CPU Core #03
8/12/2022 7:07:33 PM 1.931613 CPU Core #03
8/12/2022 7:08:37 PM 0 CPU Core #03
8/12/2022 7:13:37 PM 0.6329114 CPU Core #03
